Surf SOHO HW Refresh?
#1
Hi, the last reveision MK3 was released 2.5 years ago or so. Is hw refresh soon in the plans?
#2
The link below may be useful.
#3
Thx, bit I was asking about a hardware refresh. The MK3 is a third generation, which is a 2.5y old.
#4
My Bad.
I guess there needs to be a reason to change the hardware. The firmware updates add features ,etc. to make the units more useful.
#5
Well, 2.5 years later the speeds that consumers & small businesses can get for a very reasonable price are much higheer than the supported 120M and the wave 1 AC chipset is now slow.
But I guess, it all depends on Peplink’s vision for this device: it is probably still adequate for use with cellular connections. I would not know that, but I would definitely update my unit to a faster version to take advantage of higher speeds available today.
