Does the Surf SOHO now have the ‘Hot failover’ feature when connected to two WANs using the bonding service via the Speedfusion Cloud? ie. will it failover without any connectivity issues so for example a Teams call will not drop.
SOHO supports SpeedFusion bonding as long as the SpeedFusion Cloud is activated. You can put 2 or more WANs into the same priority in the SpeedFusion Cloud profile. Team call will not be affected if one of the WAN links is down.
