I want to set up static IP addresses for my home network and disable DHCP on my Surf SOHO. My question is do i input my Static IP addresses in the Static Route Setting field below DHCP or is there another place to do this?
If anyone can advise me on this that would be great!
No, you would not enter anything in that field. You just need to disable the DHCP server and then you would manually assign the static IPs to each of the devices on your network.
Dear Tim,
Thank you for your help! Everything worked fine. As a new Pepwave user, you will probably see me asking more simple questions in the future about DNS and VPN. Thanks again for your help and expertise.
