I would like to know if the Surf On-The-Go can use a USB 4G LTE modem as the primary WAN and share this with the ethernet port. I would also like the Surf On-The-Go to act as VPN client (L2TP preferably). The end result is to make a device plugged into the ethernet port appear as if it is on my home network.
Can you please let me know if this is possible?
