Support OSPF for cellular interface
Dear all,
Would you please advise about the possibility of enabling the cellular interface of HD2 box under OSPF area.
As only the wan and lan interfaces are there but cellure is not.
Could you please let us know if there is a possibility for this option?
Thank you.
Gentle reminder please
:thinking::thinking::thinking::thinking: hmmmmm
Cellular enabled with OSPF route ? Can you share your use case for the cellular WAN with OSPF route ?
Our case is the customer having branches connected over 4G to the head office, and the connectivity is going through the operator network, and the routing is OSPF.
The customer now is using 4G Cisco router which supports only one SIM card, and wants to replace it with another device that is supporting more than one SIM card to improve the speed.
The customer has enabled OSPF routing on the Cisco router for the branches.
We are testing to replace the 4g Cisco router of the branches and for this case we need Cellular enabled with OSPF rout.
Thank you
Can I confirm the branch side is using private APN?
Yes, private APN
This is a rare case. We do not support OSPF on cellular WAN interface. I will move this thread to feature request for the team to take consideration.
