I try to manage AP one through InControl ans until now, it works for basic feature but for my deployement I need to activate the “guest isolation” feature on one of my two ssid.
First seem the check box is not available in InControl
Second as my SSID config is push by IncOntrol, when I activate the “Isolation” locally in the AP, when the AP request config update from IC, feature is didable.
Thanks a lot for your answer.
For sure it should be a good feature specilly for managing large AP deployment.
Waiting for this integration, is it possible at minimum, not to disable the “guest” feature configured locally when IC push the config ??
Do you have an estimated date of when this function will be available in IC2?
I have a good opportunity for customer and want to know approximaly when this feature will be in IC2.
