Support for NX protocol in InTouch
I would liketo use InTouch with NoMachine to manage some linux-based hosts behind my Peplink router. I noticed RDP is one of the available options but NX is not. Is it possible to add support for NX? Thanks.
Nice…
I don’t know it…
+1
I would find this useful - although VNC is supported, NX would be a welcomed addition here. However… NX is a bit tricky as there’s a lot of versions of them…
  • FreeNX which is unmainted.
  • NeatX
  • Xpra
  • X2Go
And I’m sure there’s many more…
What version are you considering mostly used @erd ?
Which version would make most sense for your deployments?
I’d think FreeNX or X2Go would be the most common ones
