¿Es posible sumar los anchos de banda de las 2 tarjetas sims en un Max BR1?
No. The two SIMs are used one at a time, you can’t use them together to bond the bandwidth, but you can use the monthly bandwidth allowance one one SIM then the other in sequence.
