I have little background in cellular integrated network devices and feel unprepared to be forced into this area.
My need is the need for wi-fi access to the internet for 3 or 4 of Hunter’s hydra-wise wi-fi irrigation/sprinkler controllers. There is no public wi-fi access available. The only method iI know s to rely on cellular-based hotspots.
The products like Verizon’s jetpack lack wi-fi range to connect to any of my other controllers despite three controllers within 200 feet point to point, and I would need one jetpack type device per controller, which gets more costly than I would like.
I have the idea that using a product like your MAX BR1 Mini Core could solve this problem and have a single cellular connection.
There will be no wired network connections. Is this product usable if placed in a waterproof enclosure for this application?
Do you have a better product suitable for direct outdoor use that is price competitive with the mini?
I can’t find the sim type and wonder will a Verizon jetpack sim will fit, or do I need to acquire a new one? Do I contact the cell provider to provide a new SIM?
Do you offer any remote antenna with cables? All I found on the website were the direct mount to the unit types.
Sorry for being an idiot, and I appreciate any help.
