A customer of mine wants to make live streaming from his yacht and his prefered
streaming platforms/application would be:
YouTube,
Tich,
Facebook
with a 1080p resolution.
Looking at those service minimum requested bandwidth is 8Mbit/s.
My idea is to install and HD2 mini or HD2 dome to use both LTE radios, and I’m wondering if setting up a SpeedFusion VPN would be prefered and advised to have a reliable live streaming.
Waiting for any suggestions and thanking in advance for you advices I send you all my best regards.
Hi. Is the plan for the yacht to be on the move or stationary?
Peplink have recently launched their maritime Peplink certified engineer certificate so there is a massive amount of material for you to have look through to help you.
You could start here and look at this play list:
I my be able to help for TV I suggest AT&T now but I think 720 is a reasonable solution to the massive amounts of data you will need to stream going to need about a gig per hour per tv I need about 300 gig per month but again if you’re moving your going to have drops in service and reloads more data😒 I lov streaming Netflix is good about adjusting their speeds
