I have a Max Transit Duo and I’m getting a 2 second delay every 10 seconds even on local resources. Here is a ping between two laptops on the network:
64 bytes from 192.168.1.33: icmp_seq=786 ttl=128 time=3.077 ms
64 bytes from 192.168.1.33: icmp_seq=787 ttl=128 time=3.558 ms
64 bytes from 192.168.1.33: icmp_seq=788 ttl=128 time=1.704 ms
64 bytes from 192.168.1.33: icmp_seq=789 ttl=128 time=1401.685 ms
64 bytes from 192.168.1.33: icmp_seq=790 ttl=128 time=404.947 ms
64 bytes from 192.168.1.33: icmp_seq=791 ttl=128 time=2.736 ms
64 bytes from 192.168.1.33: icmp_seq=792 ttl=128 time=2.571 ms
64 bytes from 192.168.1.33: icmp_seq=793 ttl=128 time=3.199 ms
64 bytes from 192.168.1.33: icmp_seq=794 ttl=128 time=3.450 ms
64 bytes from 192.168.1.33: icmp_seq=795 ttl=128 time=2.995 ms
64 bytes from 192.168.1.33: icmp_seq=796 ttl=128 time=3.058 ms
64 bytes from 192.168.1.33: icmp_seq=797 ttl=128 time=2.834 ms
64 bytes from 192.168.1.33: icmp_seq=798 ttl=128 time=3.280 ms
64 bytes from 192.168.1.33: icmp_seq=799 ttl=128 time=1439.750 ms
64 bytes from 192.168.1.33: icmp_seq=800 ttl=128 time=475.929 ms
64 bytes from 192.168.1.33: icmp_seq=801 ttl=128 time=2.956 ms
64 bytes from 192.168.1.33: icmp_seq=802 ttl=128 time=3.488 ms
64 bytes from 192.168.1.33: icmp_seq=803 ttl=128 time=2.729 ms
64 bytes from 192.168.1.33: icmp_seq=804 ttl=128 time=2.891 ms
64 bytes from 192.168.1.33: icmp_seq=805 ttl=128 time=3.789 ms
64 bytes from 192.168.1.33: icmp_seq=806 ttl=128 time=2.793 ms
64 bytes from 192.168.1.33: icmp_seq=807 ttl=128 time=1.940 ms
64 bytes from 192.168.1.33: icmp_seq=808 ttl=128 time=1.735 ms
64 bytes from 192.168.1.33: icmp_seq=809 ttl=128 time=727.869 ms
64 bytes from 192.168.1.33: icmp_seq=810 ttl=128 time=2.971 ms
64 bytes from 192.168.1.33: icmp_seq=811 ttl=128 time=2.129 ms
64 bytes from 192.168.1.33: icmp_seq=812 ttl=128 time=3.370 ms
64 bytes from 192.168.1.33: icmp_seq=813 ttl=128 time=1.887 ms
64 bytes from 192.168.1.33: icmp_seq=814 ttl=128 time=5.286 ms
64 bytes from 192.168.1.33: icmp_seq=815 ttl=128 time=1.990 ms
64 bytes from 192.168.1.33: icmp_seq=816 ttl=128 time=2.762 ms
64 bytes from 192.168.1.33: icmp_seq=817 ttl=128 time=2.148 ms
64 bytes from 192.168.1.33: icmp_seq=818 ttl=128 time=1.982 ms
64 bytes from 192.168.1.33: icmp_seq=819 ttl=128 time=1622.090 ms
64 bytes from 192.168.1.33: icmp_seq=820 ttl=128 time=616.059 ms
64 bytes from 192.168.1.33: icmp_seq=821 ttl=128 time=2.069 ms
64 bytes from 192.168.1.33: icmp_seq=822 ttl=128 time=2.298 ms
64 bytes from 192.168.1.33: icmp_seq=823 ttl=128 time=1.909 ms
This also occurs at the exact same moment, when a third computer pinging google.com.
Any ideas, its quite annoying!
Tyler
