How do we turn off the port event logging? I can’t seem to find this in my B one.
Hi Rossh,
Do you want to completely shut down the Port event logs?
Or specific messages in the logging?
Not sure if any or both are possible. Might be a feature request.
Hi, @rossh_pl_beta
Are you asking about LAN?
Do you know how see the support page of your device?
sample
https://192.168.50.1/cgi-bin/MANGA/index.cgi?mode=config&option=firewall
change to AFTER your logon
https://192.168.50.1/cgi-bin/MANGA/support.cgi
then
search for " [Experimental] Event Log Management "
LAN port status logging Auto Turn On Turn Off
SAVE your option…
Back to standard dashboard… refresh… do a apply.
okay?
Thank you for this. On my new B-One, it does not have this. The experimental lets me fiddle with buffer sizes, but not the event logging. On my older Core One, it allowed for this - deactivate the LAN port events. But its not there in this new B-One - how disappointing.
weird…
I look at the old MAX700 hw3… running 8.4.1s032 build 5637.
and… It have LAN option…
