Step-by-Step Guide: Configuring Iridium as a Backup WAN and Enabling Out-of-band Management with Peplink Routers
Device: BR1 Pro 5G (with active PrimeCare)
Available WAN Connections:
  • Satellite LEO (via Ethernet WAN)
  • Cellular WAN (5G/LTE)
  • Satellite Iridium (Virtual WAN)
Objective:
Configure the BR1 Pro 5G for use with Iridium as a backup connection, and enable InTouch to access remote LAN-side devices via this satellite link.
This guide provides step-by-step instructions to:
  • I. Enable the Virtual WAN interface for Iridium
  • II. Configure SpeedFusion for failover and secure and reliable traffic routing over Iridium
  • III. Configure Outbound Policy to route traffic through SpeedFusion over Iridium only when all other WAN connections are unavailable
  • IV. Set up InTouch for remote access to LAN-side devices
Note: This document demonstrates a basic configuration. Alternative setups are possible depending on specific deployment needs, but the following serves as a recommended reference for most standard use cases.
I. Enable and configure Virtual WAN
Notes:
  • The BR1 Pro 5G has one Virtual WAN enabled by a valid PrimeCare subscription.
  • A permanent Virtual WAN license (SKU LIC-VWAN) can be purchased if there are no plans to continue using PrimeCare subscription.
Step 1. Open Virtual WAN settings
  • Connect to the router WEB configuration interface.
  • Go to Dashboard and click on virtual WAN interface - VLAN WAN 1.
Step 2. Change Virtual WAN settings
  • [optional] Change WAN connection Name to any you prefer.
  • Uplink Interface change to LAN.
  • Change the VLAN setting to an unused value. In our example we choose 10.
Step 3. Save and Apply
  • Scroll down and click Save & Apply.
Step 4. Configure which LAN port will be used as Virtual WAN
  • Go to Network (top) tab and then click Port Settings (left side)
  • Click on the port you want to assign as WAN. In our example we will configure LAN2 interface as WAN.
  • Port Type change to Access.
  • For VLAN Networks select the VLAN which you assigned for Virtual WAN. For this configuration example it is 10.
  • Click Save and then click Apply Changes as shown below
Step 5. Enable Virtual WAN interface
  • Drag the Virtual interface to priority 1 as shown. The result is shown below
II. Enable and configure SpeedFusion Connect
  • Go to SF Connect (top) tab and click on Client Mode - for Outbound accesses
Step 2. Select SpeedFusion location
  • Select SpeedFusion server location and then click the green box to save settings.
  • Click Apply Changes.
Step 3. Configure SpeedFusion tunnel
  • Click on the tunnel name
  • Set Forward Error Correction to High.
  • Disable all WAN connections and leave only Iridium since we plan to pass SpeedFusion traffic only via Iridium.
  • Scroll down and click Save.
III. Outbound Policy configuration (traffic steering rules)
Note: for this example we pass traffic via Iridium using SpeedFusion only when other WAN connections are down. WAN connection is marked as not available based on Health Check settings for each WAN interface.
Step 1. Modify Outbound Policy for primary WAN connections
  • Go to the Advanced (top) tab and click on Outbound Policy (left side).
  • Click on the main Policy rule to adjust it.
  • Select Algorithm as Priority
  • Change Protocol to Any
  • Change Port to Any
  • Modify Priority Order by leaving only WAN connections which are used as primary. All traffic will be load balanced via these WAN interfaces as long as they are available.
  • Change When No Connections Are Available rule to Fall-through to Next Rule.
Step 2. Create a rule for passing traffic via Iridium.
  • Click on Add Rule
  • Set Service Name. In our example it is Iridium backup.
  • Change Destination to Any.
  • Change Algorithm to Enforced.
  • For Enforced Connection choose SpeedFusion tunnel name. In our case it is SFC:SFC.
Note: it is also possible to configure to allow only certain traffic via Iridium. For instance by using Source you can define by IP Address or MAC or client type, etc.
  • Click Save.
  • Drag and drop iridium rule to the bottom as shown in the example
IV. Configure InTouch to securely connect to remote devices
Note: via InTouch you can access devices connected to WAN or LAN ports of a Peplink router.
Step 1. Connect to InControl and open InTouch configuration
  • Log into your InControl2 account at https://incontrol2.peplink.com
  • Select the Organization, then Group of the router you want to access devices behind
  • Click on the router device from the group to open the Device Details page
  • Hover over the Settings tab and select InTouch
Step 2. Configure InTouch
  • Click Add to add new device accessible via InTouch service
  • Create a friendly name for a device and then fill in other settings such as device IP address, port and click Save Changes.
Step 3. Access Remote device via InTouch
  • Go device Dashboard in InControl. Click on InTouch and select the remote device you want to access.
  • A new page will open and you will be connected to the remote device WEB configuration interface.
