I have a Peplink Balance 20. The Peplink is connected to a UPS, and when we had a power outage, I shut everything down and removed the plugs.
When the power was restored, I plugged the Peplink back into the UPS, and turned on the PC. I noticed that the Status light was red (while Power was green, and the cable modem and DSL lights were transmitting/green). I could not connect to the Peplink (192.168.1.1) and the red light stayed on for more than 5 minutes. Then, it turned green, and all worked as expected.
Is this normal, or what should I do to check?
I don’t think it matters, but the firmware is 8.0.0. build 3623. Thank you.
