Dears,
I have a question of the Peplink balance 30 LTE, have it form of add static routes?
Regards…
Dears,
Regards…
you can add static routes on the LAN side and use outbound policy on the wan side
The Peplink 30 LTE (192.168.20.1/10.10.230.215) should have routes for both of those networks if they are both /24’s.
What is the gateway IP on each machine?
Dear bryn.loftus,
The gateway is:
PC10 is 10.10.230.126
PC20 is 192.168.20.1
I need to be able to reach the Speedfusion (192.168.10.XX) equipments from PC10
Regards…
Then you need a route for 192.168.10.0/24 pointing to 10.10.230.215 on either PC10 or the router at 10.10.230.126.
Return path traffic should be fine, as the remote end already knows about 10.10.230.xxx
If you put that static route on the router 10.10.230.126, it will cause asymmetric routing as the outbound traffic from PC10 will go though the router but the return path traffic will not. If anything is doing state tracking (the router or the firewall on PC10) then it will break.
