hello,
hello,
im connect 2 devices(hd4, br1) with speedfusion tunnels between fusionhub.
im want config static route in fusionhub to tunnel between fusionhub to br1.
how im config next hop to to tunnel?
Fusionhub has limited routing capabilities. You can add a static route but I suspect that isn’t what you need here.
Instead if you add a static route to the BR1 (I assume the next hop is the LAN side of the BR1?) then it will get advertised to the fusionhub over OSPF and then the HD4 will get that advertised too and so learn the route via the Fusionhub.
If that doesn’t make sense post a diagram with IP addressing so we can help.
