On the WAN side is an ISP connection with 5 public IPs, 50.85.0.248/29
ISP = 50.85.0.249
ISP connects to a 4 port unmanaged switch
I have two devices plugged into the 4 port unnamaged switch.
Cisco 871 = 50.85.0.253 on the WAN side and 10.10.10.1/24 on the LAN
Peplink Balance One = 50.85.0.254 on the WAN side and 10.10.10.2 on the LAN side
The Cisco and the Peplink each have one cable running from LAN to 24 port unmanaged switch.
The Cisco has a DMVPN and when I use 10.10.10.1 as my GW from my PC I can reach any subnet on my corporate network.
I prefer to use the Peplink for WAN redundancy and 4G LTE failover and it works fine unless I want to reach routes on my corporate network.
So, I added a static route of 10.0.0.0/8 in the Peplink LAN settings with a gateway of 10.10.10.1.
If I tracert from my PC (10.10.10.5) with gateway 10.10.10.2 to 10.20.20.20 my second hop is 50.85.0.249 out of my Peplink WAN instead of through my Cisco to my corporate network.
If you mean point my gateway to 10.10.10.2 (Peplink) then my tracert to corp (10.20.20.20) from PC (10.10.10.5) after removing static route, then the trace is identical to what it is with the static route in place. The next hop in the trace is my WAN gateway 50.85.0.254 with or without the static route in place on the Peplink.
If the static route were in place and working the next hop in my trace should be my Cisco inside IP then the other side of my DMVPN tunnel but it’s not.
Bingo! I was on 6.2.0 and applied 6.2.1 and now its working as expected.
Now hop 1 is Peplink, hop2 is cisco, hop 3 VPN tunnel, 4 is core switch, 5th is host.
