Just bought a Balance 30 and need to setup the WAN PPPoE with a static IP address is that possible?
Yes, you can set the WAN connection type to PPoE in the Balance. See screenshot below for reference.
How do you set it with at static IP address?
The Balance will receive the Static IP address once the PPoE information is entered as long as the ISP modem is set to bridged mode.
It worked!
thank you
