Troubleshooting on how to not get this error message.
Goal
WiFi via either Cell or Starlink through the same Pepwave WifI home network. This allows me to switch between Starlink and Cell without having to tell each device the name of the network in use.
I’m trying to get set up 2 or 3 to work. Set up 1 is proof that all hardware is working only.
Set Up 01
- Starlink router as WiFi device as input to Pepwave
- Cell active as input in Pepwave
result
Works. Starlink speeds are slow compared to direct WiFi to Starlink
Set Up 02
- Power down everything
- Power up Pepwave
- Power up Netgear
- Power up Starlink
- Starlink is pluged into Ethernet Adapter
- Ethernet Adapter is plugged into Netgear ProSAFE
- ProSAFE goes into Pepwave
result
Cell is fine
Starlink - WAN failed HTTP test
Set Up 03
- Ethernet Adapter is plugged into Pepwave
result
Cell is fine
