We have a Peplink MAX HD1 Dome Pro 5G router with 2 Sim Cards and are considering adding the Starlink High Performance as a backup WAN. We intend to purchase the feature add-on license for 1x Virtual WAN. The Starlink Ethernet will be connected to the switch to a separate VLAN on the SD switch, and we assume the VWAN will be configured through this VLAN ID. Our query is whether the Starlink needs to be put into bypass mode or if it can operate directly.
Both modes should be fine.
