It is great to see the integration of Starlink to Balance 20X.
One of the key features would be the GPS data from Starlink.
It is not available on Balance 20X.
I do hope that it would be make possible.
I have a deployment of 40+ units and this will be a great enhancement for us.
Thanks.
We at 1SimpleConnect are an Authorized Peplink & Starlink Solution Provider and can help you with purchasing the equipment and also help with post sales. The feature that you requested has been added in 8.4.1 , You can PM me or e-mail me at [email protected] and I can assist you in getting this working.
The map on this post: Peplink | Pepwave - Forum was generated using starlink gps data.
We are already on 8.4.1 and it is not available for Balance 20X.
Thanks for your offer.
Are you using 8.4.1 GA release?
Make sure you enable the Starlink Location “allow access on local network” in the Starlink App.
Jonathan,
That is the solution. I tested on 1 and it is working.
I am going to do it for the rest of the Starlinks.
Thanks.
