I would love the Starlink feature in Beta to be added to Balance Two, for backup residential use… Not sure if its possible, or who else would like it to be supported.
It won’t be possible as this feature is CPU intensive.
Minimum requirement is a BR1 Pro 4G. Time to upgrade… With the included virtual WAN, you should have everything you need.
This is a quick referrence from the 8.4 release notes of devices that support starlink.
Balance: 310X, 380X, 580X, 310 5G/Fiber 5G, 305/380 or above
MAX: BR1 Pro 5G, BR1 Pro HW7, BR2 Pro, Transit 5G, HD1 Dome/Dome Pro, HD2/4 MBX
MediaFast: 500, 750 PDX, SDX, SDX Pro, EPX
I’m surprised… the Balance Two doesn’t have enough CPU for this feature ???
Agree, especially since processing power was supposedly the justification for a 250% higher price than the Balance One Core, while also having fewer LAN ports.
