Stack Exchange servers miscategorized as File Hosting
Browsing a Stack Exchange site (e.g., stackoverflow.com) when the File Hosting category is blocked is frustrating because of disorganized formatting and no images.
This entry in the content filtering database seems to be at fault:
filehosting,sstatic.net
According to a Stack Exchange post, sstatic.net serves static content for these sites.
@Daniel_Eble I can confirm seeing the same as yours and will inform the team to update it.
Meanwhile, as a workaround, you may put this under the Exempted Domains list, it should help while our team is working on the fix.
I have done so. Thank you for taking the time to respond.
Using Content Filtering Database r20241014, this is no longer a problem. Thank you.
