hi guys
I use SRX-240 and peplink 580 to build a vpn tunnel, but the vpn was unstable.
I always need to disable and enable the tunnel, when the vpn was disconnected.
How can I fix this problem? thx.
hi guys
Hi Ethan,
Possible to let us know the firmware version running for the Balance 580 ? Please make sure you are using the latest firmware. You can download the latest firmware by using the URL below:
If you still having issue after upgrading to the latest firmware, please open a support ticket here for the team to further check.
Thank You
Hello sitloongs:
our FW version is 6.2.0 build 1333.
do you suggest us to upgrade it?
Hi all,
Please upgrade to v6.3.1. We do have the related fixes on this.
Thank you.
thx.
I will try it, then observed the vpn setting.
make sure it will be better.
