I´ve heard that SRT video stream can´t use bonding networks like Speedfusion , has anybody tested this ? My idea is use an SRT Sony camera , connected via WiFi to a MAX BR2 Pro with 2 SIMs and send , via Speedfusion to a B One at central studios , and I´m looking for tests and experiences from other users , can anybody help me ?
Hello, @jrequena
I had a customer… with 22 remote tst-duo (not pro) and one bpl-305 (headquarters) using voip and srt without issues, with speedfusion.
OK, can you share the settings ? I found this in the forum , concerning the MTU size of SRT and the expected size in Speedfusion …: SRT link is blocked by speed fusion VPN
Hi…
Model: Peplink Balance 305
Firmware: 8.4.1s032 build 5280
Uptime: 397 days 18 hours 48 minutes
Model: Pepwave MAX Transit (old)
Firmware: 8.4.1s032 build 5637
Uptime: 0 days 0 hours 52 minutes
Because there is a live transmition… before begin at every event… I change the receive buffer of both side… never greater than 1.5 seconds.
MTU
Cell
Dashboard > Advanced > Speedfusion VPN > New Profile
same path… same screen.
Please… take a look at this url… may help you…
SRT over speedfusion 100% works, BUT beware when using Cellular that you have headroom to accomodate the inevitable retransmits that happen when the connection speed drops for a moment. I typically disable FEC and Smoothing and let SRT do it’s thing.
