Would like to know if the Franklin U772 modem will work with the Surf to Go.
We already support the Franklin U770 so the 772 will probably work out of the box. Otherwise you can connect it up and open a support ticket with us so the developers can get in to look at building a driver. Thanks.
We’re wondering if there is a definitive answer on this. Hoverdave, if you tried this did it in fact work out of the box?
Yes it did not problems at all.
Yes it works perfectly.
