Splitter MAX - Power & Data, Split for Greater Flexibility
Only have a PoE connection for power, but your device doesn’t support PoE input?
Splitter MAX makes it simple — cleanly splitting power and data from a single PoE line, so you can easily connect devices that don’t support PoE input.
Built with an industrial-grade design and a wide operating temperature range, Splitter MAX is ready for deployment in tough environments.
Why Splitter MAX?
  • Power Surge Protection — Keeps your devices safe
  • Compact & Versatile — Easily fits inside Peplink Antenna MAX or powers devices like CCTV cameras
  • Flexible Deployment — No extra cabling or converters needed, ideal for industrial or space-constrained setups
Learn more
