Speedtest.net On demand test and shared image link return
Now that we have connection tests in IC2 one of which runs speedtest.net tests I think,
can we please have a speedtest button in the UI (either on device on in IC2) that lets us run a test on demand and then logs to the event log the link to the image?
eg https://www.speedtest.net/result/15738456737.png
I would like to have a drop down next to the button that lets me select any WAN or SpeedFusion Tunnel to run the test against.
Yes I know and understand the limitations of speedtest.net as a service BUT it is how customers measure their speeds so being able to remotely trigger these on demand (and test the impact of tweaking settings as if I’m a user on site) would be really useful.
I support this feature, or a similar subset of.
The ability to do something similar would be useful.
Also, features other brands have that can run from the router on each WAN link would be useful to determine speeds.
Example attached of what Celerway does.
It’s in a werid place to do manually, I agree it should be on the wan page of the device itself.
Go to group → network settings → connection tests
It also only logs to the speedtest graph under a different place
Device level → device → reports> connection test reports.
Absolutely - but for customer that wants a simple “speedtest NOW” button… This would help :smiley:
And also something they “understand”…
@Michael can you please review feasible of adding a quick speed test button on the device dash board or the
Device level → device → reports> connection test reports page ? It is a challenge to navigate the current method.
Also logging the results in the event log on manual and automatic triggers could be helpful as well.
Yes, and those graphs are great but when you need a one off test is overkill, I’d love to see the speedtest.net image link available. maybe in the tooltip?
I agree. This is a must have to please end customers and many other competing routers offer it. For example, this is prominently displayed as one of the tools in Cradlepoint routers and can be run from the cloud portal. See screenshot below:
I am the founding member of “CAST” Campain Against Speed Testing
Stop wasting bandwidth, it affects us all and slows down the entire World Wide Web
Joking aside though, I think it’s a great idea.
We did it with a KVM for one of our clients so they did have a one click option, but in the UI would be just perfect.
We have done similar thing in Docker… But again, not as nice and not possible on non-docker devices.
We will add a button menu (like the InTouch one) at the device level for initiating one of the connection tests that are defined for the device. Thanks for your suggestion.
Thanks!
Thanks for doing that.
In order to understand the data returned by the speed tests, could you share with us what connection is being tested (i.e., what is the other end-point of the test)? The most local speedtest.net site?
[Update:] Found it. The endpoint is identified in the detailed information about the individual test below the graph, and (for some) also in the log in the panel displayed when hovering on a particular speed test in the graph.
Cheers,
Z
Hi Nik:
What docker image did you run for the speedtests? I’ve got a BR2 with edge computing available.
Hey Luke,
We’ve used below images,
henrywhitaker3/speedtest-tracker - Docker Image | Docker Hub
adolfintel/speedtest - Docker Image | Docker Hub
Both are available if you search for docker images on the server.
Thanks, Captain! I’ll try them both out.
I would also suggest to adding a note at “Group Level → Connection Test Reports” to indicate that the detailed report is at “Device Level → Connection Test Reports”
We often receive comments of people that configure the test (group level) and then go to the reports (group level too) but they are not able to see the detailed report, so they ask us why they cannot see the results of the test.
Just a suggestion…
