I have two pepwaves ubr lte and i want to merge the internet connection from both into a peplink balance 305 using the pepvpn … but i don’t know how to go about it
- login to one of the UBRs. Change the LAN IP from 192.168.50.1 to 192.168.51.1 (DHCP range too).
- Plug one UBR LAN into WAN1 on the B305 and the other into WAN2
- Power everything up and the B305 should now have load balanced internet access.
- Enable SpeedFusion Cloud on the B305 and you will have a bonded connection.
Do 1-3 above then watch this for speedfusion cloud https://youtu.be/asxU2ZFel8A
Good luck!
