I have a max transit duo that uses wan smoothing over two cellular links and an ethernet WAN link. This all works great.
I now have an additional wan over wifi link I want to add into the mix. What I would like to do is have speedfusion prefer the wifi link if it is available, that is, when wifi wan is not available: bond and smooth traffic over 2 cellular + 1 ethernet wan. When wifi wan is available: only send traffic over wifi wan link.
Is it possible to configure speedfusion to behave like that?
The Peplink device wan priority level is about what links are available to use, within the Speedfusion config you can set different priority levels for the wan links (which can only apply to wan links that are available from the device).
I’m trying to confirm what “priority” means for the speedfusion config. Does it mean that if a priority 1 link is available it won’t use a priority 2 link at all?
