Can the wan connection priority in a speedfusion cloud profile overide the default wan connection priorities? Max transit Duo. I want to run only my unlimited verizon sim for the default SSID but have the profile also bond the ATT card when traffic is seen on the speedfusion linked wifi.
To clarify I have a verizon sim card in highest priority and att card in priority 2. in the speedfusion wan connection priority I have them both set to highest. the att stays in standby however even while speedfusion traffic sees active traffic
Yes the sf wan priorities can override the wan connection priorities, as long as it’s either in the same active priority or in standby, not disabled or cold standby on the wan dashboard. I believe if it’s cold standby on the dashboard it only becomes active if other wans fail.
