We recently built a SpeedFusion VPN topology to connect remote branches to FusionHubs to provide Internet access with public static IPs on the Peplink LAN via pure Layer 3 tunnels. The setup uses:
2 x FusionHubs for redundancy Internet Access.
1 x FusionHub for secure remote management access only via private IP space.
All FusionHubs are configured in IP forwarding mode
The entire topology setup is just working fine. Very quick failover and reliable.
But however during simulated failover tests we noticed some tunnels at the remote branch side only to change status from Established to Updating Routes while on FusionHub side all tunnels are always in Established. Despite this, traffic continues to work normally after the failover and no routing conflicts are observed. In the logs there is no any information that can point us for a possible issue. Once reboot the router all tunnels are in Established state again.
In our LAB topology each branch is connected via two WAN interfaces: 1 x Broadband Internet and 1 x Starlink. Config is very basic, no special settings. I’m attaching screenshots when the remote branch device is freshly rebooted where all Speedfusion VPN Hubs are established. And 1 x screenshot where simulate WAN failover (two HUBs are stuck in Updating Routes). Also providing the Speedfusion VPN config.
I will be very happy and highly appreciate if someone can help us to find what might cause this issue. If it is just a cosmetic bug in WEB GUI or a real issue but in both of the cases we need assistance to find the issue caused it.
