Speedfusion VPN shows WAN1 down though it is actually up
Speedfusion VPN shows WAN1 down though it is actually up. Please advise how to fix this
Can you ping on WAN1 out? Say to 8.8.8.8 ?
Yes that worked. We fixed the issue by disabling and enabling the WAN1 interface. WAN1 got added to the tunnel.
Is WAN 1 a starlink?
Yes WAN1 is starlink
Make sure you set MTU to 1500, and ideally enable the Starlink module on WAN1 for more information.
And change Health Check as well to PING instead of DNS lookup - sometimes can make false-positive results.
