I am having trouble accessing a server-side VLAN from a remote client over a SpeedFusion VPN. I am not using InControl. Full configuration details are below.
Goal
Allow hosts on the remote VLAN 321 (172.22.0.0/24) to access all 172.20.x.x networks on the server side (Homebase). This does not work today.
What works
Hosts on VLAN 321 (172.22.0.0/24) and the untagged LAN (10.43.0.0/24) can reach:
- Homebase VLAN 1 (10.28.42.0/24)
- Homebase VLAN 99 (10.28.99.0/24)
SpeedFusion is up and stable. Under Status > SpeedFusion VPN, the tunnel is connected and all VLANs appear.
Notes
- I previously had firewall rules restricting some 192.168.x.0/24 traffic, but all of those rules are now disabled.
- The only remaining custom rule is an outbound policy on the BR1 that forces VLAN 331 (192.168.32.0/24) into the VPN.
- That rule should not affect VLAN 321 (172.22.0.0/24), yet VLAN 321 still cannot reach any 172.20.x.x network on Homebase.
Any suggestions on what I may be missing?
Server configuration (Peplink B One – “Homebase”)
LAN and VLANs
- Untagged LAN (VLAN 1): 10.28.42.0/24
- VLAN 21: 172.20.0.0/24
- VLAN 22: 172.20.1.0/24
- VLAN 23: 172.20.2.0/24
- VLAN 31: 192.168.31.0/24
- VLAN 51: 172.20.51.0/24
- VLAN 99: 10.28.99.0/24
All VLANs use x.x.x.1 as the gateway on the device.
SpeedFusion VPN
- Single profile between Homebase and BR1
- Encryption OFF
- Authentication: Remote ID + pre-shared key
- NAT disabled
- Remote IP blank
- Cost 10
- Data port Auto
- No bandwidth limit
- Packet fragmentation Always
Firewall
- Outbound: default allow all
- Inbound: default allow all
- Internal: default allow all
Remote configuration (Pepwave MAX BR1 MK2 – “BR1”)
LAN and VLANs
- Untagged LAN: 10.43.0.0/24
- VLAN 321: 172.22.0.0/24
- VLAN 331: 192.168.32.0/24
SpeedFusion VPN
- Single profile between BR1 and Homebase
- Encryption OFF
- NAT disabled
- Remote host via dynamic DNS
- Cost 10
- Data port Auto
- WAN smoothing OFF
- Forward error correction OFF
- Receive buffer 0 ms
Firewall
- Inbound: default allow all from any WAN
- IDS/DoS: disabled
- Local services: default allow all
Outbound policy
- One custom rule forces VLAN 331 (192.168.32.0/24) into the SpeedFusion tunnel
- Priority-based
- SpeedFusion set as highest priority
- All WAN interfaces excluded
- Drop traffic if VPN is unavailable
- Do not terminate sessions on recovery
