We have several customer sites connected to fusionhubs. It would be great to have a quick slider to enable/disable the tunnel instead of having to go through each one manually and untick or tick off the enable for each profile. When troubleshooting it’s a huge time sink to go through each profile one at a time.
ie.
Please also make this an action, immediate so it doesn’t require an apply action.
I like this idea, but think it should be on the status > Speedfusion view instead so you can have all the info you need to know that you are turning off the right one.
I also think the first one you do in a session should pop up with a warning so users don’t accidentally start flicking radio buttons without knowing it will take down a tunnel.
Should it act like the WAN toggles do in Speedfusion test view where if you disable a wan from within a tunnel and forget to reenable it, the wan is put back into service 15mins later?
Yes exactly my thoughts.
