SpeedFusion VPN for Peplink BR1 Mini LTE-A
We have 14 Peplink BR1 Mini LTE-A devices and want to set them up on a shared APN. The desired design is to setup 1 unit in the datacenter as the gateway for the other units. The other 13 units will be deployed at 13 different field sites and connected to multiple devices at their respective site. The design would be a hub and spoke. Is this possible with the BR1 MINI’s.
The issue that we are having, is that the first unit connects using SpeedFusion and we can ping the end devices connected to the Peplink. However, when connecting the second Peplink, we get an error on the gateway unit in the datacenter when trying to establish a connection to the second Peplink field unit.
Hi…
Just try to understand…
How a BR1-mini handles another 13 br1-mini?
Are you using speedfusion to connect all?
Because… a BR1-mini cannot support 13 another speedfusion connections.
Are you trying to use the same ID vpn device / password to connect all?
At the datacenter side, will need a better device to handle all br1-mini devices.
Screenshot 2025-01-14 20.25.50
You will need to configure at the speedfusion setting, one by one of the BR1-mini.
each old BR1-mini / hw1 only support with PVN-LC-05 five speedfusion at same time.
each new BR1-mini / hw3 only support five speedfusion at same time.
At the datacenter… will need a device like bpl-310 or other kind of device, capable to support all 13 remote br1-mini. (simultaneous)
