Speedfusion is not working when we are using the 2G connectivity on Max700 (Fw 6.1.2) with the FusionHub, meanwhile it is working properly when we are using the 3G connectivity using the same GSM SIM card.
We got a confirmation from the GSM operator that the 2G and 3G internet connectivity is same from routing and security point of view and no additional security rules applied on the 2G internet connectivity.
We are suspecting the high latency of 2G connectivity!!!
Thanks for your reply, The problem is that we are doing a POC with an Oil and Gas field where only the 2G coverage is available, do we have any workaround for the latency issue like TCP window scaling or increasing the timeout of the tunnel initiation?
