Currently, when checking the status of the Speedfusion VPN tunnels on a device, one can check the WAN statistics and have some nice graphs. One can also export these graphs with a nice export button, but this button only exports a png image. Wouldn’t it be better to also have the possibility to log and export this data in raw CSV format?
It’s a crazy amount of time series data potentially though - think the graph is 10mins long.
What do you imagine you’d do with the data if you could export it?
can we have this with the apis?
Live access to the data that builds the graphs as and when it happens yes.
Download of the last 10mins of WAN monitoring data/stats from the device to recreate the graphs no.
Currently, it is for verification and demonstration of the tunnel functionalities in a live test environment. I want to prove the proper functioning of the tunnels and provide reports and insights on the added value and techniques.
Also, when refreshing the page or going to another one, you loose all data in the graphs, it 's not a constant floating buffer of graph data.
OK, that case, it should be possible to feed an InluxDB and build a Grafana dashboard with historic data?
