Use case:
An IC2-defined speedfusion star (hub and spoke) network.
Hub: Balance 580 behind a firewall. Fixed IP addresses, connections cannot be initiated from the outside.
Spokes: Various Balance, Max and FusinHub devices, all with at least one Static IP address.
Routing: All traffic at the spokes to be routed through the hub.
Issue:
The set-up of the PepVPN connections are stuck in “Starting…”
Observations:
- Point-to-point PepVPN connections between the B580 hub and the spokes work well
- Star PepVPN topologies where the B580 is a spoke work well.
- Star PepVPN topologies where the B580 is the hub and all the spokes are on the internal network (behind the same firewall as the B580) work well (the spoke devices can all access the hub directly)
- Star PepVPN topologies where the B580 is the hub and some of the spokes are on the internal network work only for the spoke devices that can access address the hub directly, The “outside” devices are stuck in “Starting…”
As far as I know, the only way to force routing of all traffic from the spoke devices through the hub is by employing the “Send all traffic to…” option for a star configuration (FusionHubs do not have the option to define Outbound policy rules).
Suggestions?
