The failing 305 was replaced. Running the speed tests from within the SpeedFusion Status page is interesting.
- There are 3 WANs at site 1.
- SpeedFusion bandwidth capped at 50Mpbs.
- Using 1 stream in the test.
Check this out as the WANs are being added and removed from the group and then speed is tested:
WAN1: 48 up / 48 down
WAN2: 48 up / 48 down
WAN3: 1 up / 7 down
WAN1/WAN2: 48 up / 48 down
WAN1/WAN3: 1 up / 17 down
WAN1/WAN2/WAN3 - 3 / 48 down
What this shows is WAN3 is the weakest connection and when added into the mix, the whole connection suffers.
Is this what I should expect when one WAN is a lot slower than others?
