Speedfusion - SNMP - Should reflect traffic within the tunnel
Hi!
Currently, when monitoring Speedfusion interfaces with SNMP, the values are missleading. When 1 MBit/s is tranfered through the tunnel, the SNMP-sensor is currently showing:
  • 1 MBit/s when using “standard speedfusion”
  • 2 MBit/s when using “WAN-Smoothing”
The sensor should reflect the traffic WITHIN the tunnel and not the traffic with the overhead.
Best wishes
KPS
Disagree. Knowing how much actual bandwidth each tunnel is consuming is very useful.
I would much prefer another OID endpoint for traffic within the tunnel.
Another “virtual” interface could be the solution.
