I cannot seem to find a straight answer for this. I have two devices, a BR1 Max 5G and a SpeedFusion Connect Relay. They show as having independent SpeedFusion quotas. I have an outbound rule on the BR1 that sends some traffic to the SpeedFusion Connect Relay. Is that supposed to use the quota of the BR1, the SFCR, or both?
Thanks.
It would expect it to use SFC quotas on both. @TK_Liew would be able to confirm I’m sure.
Thanks @MartinLangmaid would love to confirm if possible. It always appears to deprecate on the BR1 faster than on the SpeedFusion relay, but theres no way to really see daily/monthly usage of the quota as far as I know so I can’t dig into the details. Perhaps that is a result of me having multiple connections on the BR1 vs. 1 connection on the SpeedFusion relay?
The SFC quota will be used on the BR1 Pro 5G (I assume the model) but not the SFC Relay.
