Hello i have peplink 580 hw1 with ver 6.3.4 build 3613
and maxonthego with ver 7.0.3s022 build 2823
i see the devices in incontrol i config them to work with speed fusion
the config goes to the 2 devices even i reboot and i erased the config ang config from start
the speed fusuin alwayes in starting mode i config them to work p2p
what can be could the prob?
I would suggest you contact local Peplink partner to get help on this. They should able to check your settings and fix it quickly.
