We’re looking to simplify how we talk about SpeedFusion and the various options available with the service, including integrating the separate www.speedfusion.com website into the main www.peplink.com website as a single resource for you.
In doing this we’re looking to clarify and simplify some of the product names - I realize these names have changed in the past, so our goal is to go back to simpler and clearer, and to have names be as short as possible. Our focus is on clarifying the names, not changing the functionality or pricing. Let us know what you think in the comments below.
Name: SpeedFusion (The Product Category, and also the technology)
What it does: Makes multiple wide area network links more reliable for all types of applications; protects the reliability of applications.
New Name: SpeedFusion Connect
Previous names: SpeedFusion Cloud, SpeedFusion Connect, SpeedFusion Connect Protect, SFC, SFC Protect
What it does: Connects from a private endpoint (router or device) to a public endpoint (to the Internet).
How much it costs: Included with support plans; may require additional Usage Plan purchase depending on data usage.
What it does: Connects from a private endpoint (router or device) to another private endpoint.
How much it costs: Included with equipment purchase.
New Name: SpeedFusion Connect Usage Plans
Previous names: SpeedFusion Usage/Quota, SpeedFusion Connect Protect - Plan (A/B/C/etc), Top-up plans
What it does: Adds additional usage bandwidth to SpeedFusion Connect service How much it costs: Varies by plan size and type.
New Name: eSIM Data Plans
Previous Names: SpeedFusion Connect Protect 5G/LTE Plans
What it does: Provides eSIM cellular data connectivity; SpeedFusion Connect Usage is also included with eSIM Data Plans.
Name: SpeedFusion Connect Relay
What it does: Is a device installed behind home or office firewall that enables remote Peplink devices to connect to the home/office network, “relaying” through SpeedFusion Connect public endpoints. May require SpeedFusion Connect Usage Plan purchase depending on data usage.
How much it costs: Retail price $199
