SpeedFusion Multiple L2 VLANs
Here’s my topology:
Capture
As seen in the diagram, I configured BPL-ONE to assign DHCP for VLAN 10 to B One as an Access port. On B One, VLAN 20 is configured. I successfully set up SpeedFusion between B One and B One 5G.
However, when I try to select the VPN Profile for VLAN 20, it says ‘L2VPN profile is already bound to another LAN Profile.’
So, is there any way to send both VLAN 10 and VLAN 20 simultaneously?"
Hi, @Tent
Did you try
Screenshot 2025-01-29 05.18.33
Maybe this is not the best way to do this…
Thank you for your assistance. I have a question: The datasheet states that the maximum Number of SpeedFusion VPN Peers is 5. Does this mean 5 profiles?
Hi…
The device can have five speedfusion profiles (locations/devices)…
So… one device can have a connection to another five other devices / locations.
Each Speedfusion profile, can be " split " to support five IDs in the same SpeedFusion tunnel, between location A to location B.
B-ONE have a pay license to support ten speedfusion connections
Up to 10 PepVPN/ SpeedFusion Peers License Key for Selected Models (PVN-LC-10)
