1 . both Balance 380 - 7.1.0 2287
2 all MAX BR1 - 7.1.2 3310
Test that i made :
Balance 380 (A) β VPN to MAX BR1 (TEST1)
MAX BR1 (B) β VPN same MAX BR1 (TEST1)
Balance 380 (A) β VPN to MAX BR1 (TEST2)
MAX BR1 (B) β VPN same MAX BR1 (TEST2)
TEST1 have 2 VPN active.
TEST2 have 2 VPN active
When i disconnect the Balance 380 (A) the connection in TEST1 and in TEST2 to MAX BR1 (B) stay alive. (as expected).
Same Test the only change is BL380.
Balance 380 (B) β VPN same MAX BR1 (TEST1)
Balance 380 (B) β VPN same MAX BR1 (TEST2)
When i disconnect the Balance 380 (B) the both VPN connection in TEST1 dropped , after few seconds the VPN to (A) is reestablished
the VPN connection on TEST2 to (A) stay alive as expected
disconnect tested in 3 ways - removing the network cable , cut the power , reboot
same happen if i disconnect (B) and not (A).
VPN is defined with Layer 2 and network mask 255.255.0.0 /16 (this is my client requirements)
all MAX were connected on local network with DHCP. The BL380 (A) is on a remote site connected thru the Internet on local WAN (no cellular involved ).
No connection between (A) and (B) , you must add another BR1 that connect to the same (A) and (B).
TEST1 and TEST2 were connected at the same time what happen is that on one of them always one connection stay alive and on the otherβs both connection were cut .
When i add another BR1 (TEST3) he got the same disconnection on both VPN
In all of my test only one BR1 manage to keep one VPN alive and all other BR1 always dropped both VPN.
@David_AB, I got you now. I would suggest using the latest firmware version to do the testing. We do fix a lot of SpeedFusion related issues since 7.1.0.
Look like you are getting help from support team. Please provide the config file for both Balance 380 and BR1. We can do a test here with latest firmware version.
