So, if I have 2 balance 305’s do I need to buy the Speedfusion premium add-on for $999USD for both? or just one?
Yes, you would need to purchase it for both devices.
Thanks.
Lovely… so shoulda bought 380’s instead of 305s
Yeah, the 305 is identical spec-wise to the 380 but without the SpeedFusion capability out of the box.
You can still create a single WAN VPN (PepVPN) between the devices. Wont bond the bandwidth or fail-over between the WANs but its a great way to easily connect the two units in a non-mission critical way
