i am fairly new to the products. I currently have a Balance 20x and II am running the SpeedFusion Hub solo. As I am testing out the features. I am noticing that the FusionHub is not picking up my additional Network Ports. Is this done by design or did I do something wrong?
As in you are adding internet connections and they are not being used for the SpeedFusion VPN to your FusionHub?
If so, edit the VPN profile and make sure they are all set to Priority 1 in it.
Yes, the FusionHub only supports a single WAN & a single LAN interface (any FusionHub, not just the Solo).
