SpeedFusion Hub OVA error when setting up
I’m trying to deploy the FusionHub OVA. I downloaded the image from Peplinks “SpeedFusion user onboarding guide” and was getting below error. Was wondering if anyone else came across this recently and had a fix for it? I did reach out to our certified partner but they’re OOS today so decided to post here to see if anyone could help.
Issues detected with selected template. Details: - 125:7:VALUE_ILLEGAL: vmw:ExtraConfig element ‘‘nvram’’ with value ‘‘ovf:/file/file2’’ expects an existing File element with id ‘‘file2’’ in the References element.
NOTE: ESXi 7 is the Hypervisor we’re using.
Did u remove the nvram reference in the OVF file?
Is there already a solution available for this problem ?
Removing the NVram line does not fix the problem but creates a new one missing the reference of a vmdk.
I had to remove line #125 from fusionhub_sfcn-8.5.1s045-build5258.ovf (the one referencing “ovf:/file/file2”) and fix the SHA256 checksum in the manifest file. Once I did that, the *.ova imported fine in vCenter 7.0.3.
