I have IPsec between two Speedfusion Engine ET. Could you be so kind and please tell me how to disable ICMP to 8.8.8.8 and DNS query to www.google.com. FW is the latest 8.0.1.
WAN health check is disabled.
Best regards
Best regards
Why are you using IPSEC use PepVPN its better.
In Advanced > Service forwarding enabled DNS forwarding to local proxy this blocks DNS queries to google (unless you then use google as a DNS forwarder).
To block ICMP add a firewall rule.
Sorry for a late replay. I was out off office since last week.
I tray as you described and it’s the same situation. I try to block at all segments of firewall.
Any other idea?
Best regards
That works on Max BR1 but it doesn’t work on speedfusion engine ET.
Best regards
